problem with distributor? or coil? or maf?
rida4christ
Sorry guys I was gonna look thru the sticky above me but it won't allow it on my phone, which is how I view all this. I have this problem with my t4r sometimes its hard to start, sometimes when it has warmed up it putters as I step on the gas, sometimes it won't want to start, sometimes its just weird on the thottle responces. Now when "sometimes" is involve in a sentences of an automotive problem I've learned that it could be something electronic like a sensor or something like that, my egine ligth is not on cause someone took it out or disconected it or something. Any ideas? Thanx.
My runner was having similar issues. You may need to check the wiring. I found one burned out wire behind the instrument cluster (fixed the check engine light, temp gauge, and fuel gauge(mostly.)) And found another wire in the drivers front wheel well the fixed the running problem. Good luck.
Thanx Awz, I did also think I have wiring issues too cause thru out this rig there's wiring that has been messed with like twist and tape type stuff, so ill check that out too thanx. :)
