Programming key immobilizer? dealer only?
just curious to know if anyone knows how to program a new key the immobilizer part and the remote part on a 5th gen? My neighbor bought a new key and doesn't wanna take it to the dealer if he doesn't have to so i figured id ask on here if anyone knew
(yes he still has main key and secondary key) just wanted another key for his daughter
You can find it by searching.
I programmed my smart key fob, there is also a way to program your standard key as well.
Much cheaper to do on your own, not that hard and you can also configure some cool settings!
http://www.toyota-4runner.org/showthread.php?t=250297
Sent from my Moto G4 Plus using Tapatalk
Most "mid level" automotive scanners will do it !!...I just bought an Autel DS808 and made an extra key last week...took 2 minutes !!
To my knowledge, dealership only
Not true......
It can easily be done yourself for less than $50. I just got done programming 3 keys myself. Both the immobilizer and the wireless remotes. I put some notes and links to other threads in my mod thread here --> Key Programming
You will need techstream and a cable here's my quick notes on that -->Techstream
Search the forum for the long techstream thread if my quick notes aren't enough to get you going.
Not true......
Yes I see on your build thread about using Techstream and programming the key, and having them cut. But how did you program the wireless door lock/unlock buttons?
You program the wireless remotes using techstream as well.
You can have up to 5 wireless remotes. You can also erase all the existing immobilizer/wireless remotes and start all over with 5 new ones. Helpful if you have misplaced a key.
Wow. Is it under the “Utility” menu with the immobilizer? It didn’t program it when I programmed the chip. I’m wondering if I should erase all and start over.
No don't erase the immobilizers, the wireless remotes are done in a different spot with a whole different set of instructions.
You go to MainBody, then hit utility and it should bring up wireless remotes section. Here's a youtube video on the whole process.
If I ever meet you, I’m buying you a drink. Or three. Thank you so very much.
