Proper grease for Driveline Lube
Az4runnin
Senior Member
Is Mobilux EP 2 Moly Ok to Use on driveline. Have read that 2 types of grease is used but Not sure. JBA recommended it for there UCA's so wanted to check about its use for driveline.
I think technically its moly on the slip and lithium on the u-joints. I think the solid lubricant particles of molybdenum aren't optimal for the needle bearings in the u-joints. A lot of people just put a lithium grease in everything, but based on what I've read here, it doesn't seem to really matter. Any grease is going to be better than no grease imo.
3rd gen geasing guide, everthing probably applies to 4th: Drive/Prop Shaft Greasing Guide
4th gen geasing, I think post #5 has the type for each zerk: Greasing Driveshaft (4th Gen)
My owners manual says
Chassis Lubrication
Propeller Shafts
Spiders and Slide Yokes
Lithium base chassis grease NLGI No.2
Jhunt
