There is a lot of talk about replacing LBJ's as preventative maintenance, just going by mileage, so if you are in the camp of "don't fix it if it's not broken", then here is the procedure how to inspect the ball joints.
This is the procedure that is described in the official Toyota service manual, and I will be paraphrasing, and not using their images, so no copyrights are broken. :biggrin2:
To perform this test you will need a good dial indicator (nothing from the $1 store that binds on measurements less than 1/4"), and a good mount for it. Jack up the side of the vehicle so the suspension is not in tension, and the wheel is off the ground.
Place the dial indicator so it will measure vertical movement between the lower control arm and the steering knuckle. I'm using a gigantic rare earth magnet to hold the assembly to the lower control arms. Put some tension on the dial indicator so at rest, the needle is somewhere in the middle of the measuring range.
Now grab the wheel and pull up a few times. Have someone look at the dial. Measure deflection on the needle. Now push down on the wheel a few times. Measure deflection again. Add up the 2 numbers.
If the sum is greater than 0.5mm, or 0.02", then you have exceeded the maximum allowed wear. Better replace it. If not, you are good to go for a while. There is a big safety margin in the maximum wear figure. It's a Toyota, after all.
