mtbtim
Elite Member
Hey Y'all,
I installed steering rack and front sway bar bushings yesterday on my 2000 SR5 4x4. The Energy Suspension steering rack bushings were spot on and were a great fit. Even though my rack bushings weren't in bad shape, I can definitely detect more responsive steering now.
The Prothane sway bar bushings were a great fit also, but the end links is where I noticed a problem. The inner diameter of the end link bushings was much larger than OEM. The OEM bushings have a 3/8" hole and the Prothane bushings have a 6/10" hole. That's almost a 1/4" difference. So, the bushings don't fit snug at all on the end link posts and there's a lot of slop. Because of the sloppy fit, the bushings squeeze out a little past the washer when tightened down. And, I don't think I'm over-tightening the top nut, but maybe if I backed the nut off a little, the bushing wouldn't extend out past the washer.
I talked with a very helpful guy at Energy Suspension, Greg, and he said he called Prothane and was told the kit I got was the correct one.
So, I called Prothane and talked with a guy, Dominick, and he said they've had some problems with 3rd Gen 4runners because the trucks don't all have the same size end links. I don't know if that's accurate or not. Does anyone know if this is true that there can be different size end links on the 3rd Gen 4runners? He also said his R&D guy said it's not a big deal if the inner diameter is off. Don't know if I buy that either. If there is a difference between the 3rd Gen years, why not figure it out and make the right sizes for the appropriate years. Because they've only had around 8-10 calls regarding this problem and they've sold over 500 kits, they're thinking it's not a big issue. Dominick was helpful and I'm not bagging on him. I would just think the company would want to make a better product than what they're putting out.
The end result is Prothane is going to send me four other end link bushings with a 3/8" internal diameter that will probably work. He said they are a little taller and I might have to sand them down a bit but I'm guessing they'll fit a hell of a lot better than the ones that come in the kit.
Just figured I share this because these bushings came highly recommended on this forum but my experience with them is less than stellar.
