I was surprised, too, which is why I doubled checked he was talking shaft/rod sizes and not shock dm.
Otherwise, the Radflo 2.5 with no resi are pretty well priced at under 700 for the pair. But I am a big fan of max match between parts. And so wary of mis-matches.
Even if the shaft is okay that still creates a mismatch between front (stronger spring, softer shock) and rear (softer spring, stronger shock).
Bilstein are correct at marketing the 6112 as an adventure, not a performance shock. That's what it is. It can do everything for a long time with no unnecessary maintenance. With 650lb springs, it can go as fast as I care to go. But despite the 2.65 body it is not a powerful shock by any means. I guess resilient would be a better way to describe it. Or a great value proposition at the right price which is how I got it.
Anyway, I will give the B12 Bilstein rear spring a try. The ride is fine under most conditions anyway.
It is just that I want to see if I can do a little better. That's the fun part, no?
