Pulling to the right in 4wd
jwoo689
Just got my toytec coilover 3/2 lift installed and 275 tires. My cv boots were leaking so I replaced both axles. With the boots leaking i did not use 4wd much but I did notice my problem then. My problem is that when i give the truck some gas in 4wd it pulls to the right pretty hard. It only happens in 4wd, it does not have this problem in 2wd. Anyone had this problem? Also, I did have an alignment since the lift was installed.
Before the lift and tires I never had this problem.
I'm assuming your vehicle is a V6 since you state you have 2WD? I haven't played with too many of the V6's in 4WD beyond testing at work, but I would suspect they may have a tendency to pull to that side from the way the ADD is set up?
Post Note-
Are you sure its not there in 2WD? Maybe its not as noticeable as it is in 4WD? I know seized brake pistons can exhibit a similar symptom? Not sure if they would be exaggerated in 4WD vs. 2WD though (just rattling off possibilities relating to the symptom right now)
Yes, I have the v6. There is no pulling when I am 2wd at all. It is prefect in 2wd. The pulling only happens when I give it gas in 4wd, when I let off it goes back to straight, I literally have to grab the wheel so it doesn't go off the road when I give it gas.
D'Angelo
