Purpose built suspension?
bikewrench
I am new here and looking for advice. I have spent hours looking at different suspension set-ups. This will not be my first modified truck and I am capable of doing the work myself.
I am getting a 99-00 runner in the next few weeks. The rig will be used to haul bikes(on the roof, at least 3) and more than likely will have a Thule hard cargo box on fulltime. There will be a load of mt biking gear and other camping stuff also.
I am thinking that I would go with the Sonoran Steel Bilstein coil-overs in the front and LC coils rear. What rear shocks go best with the LC coils? Seems like a pretty solid set-up. More than likely I will do the SS adj panhard, diff drop, and extended lines. I think the only other thing I am going to need are some sway bar end links and I should be good. I prefer to keep a slight rake, even when loaded. For tires, I am going to start off w/ 265/75/16 and possibly go to 285s if I find the time to wheel more. I am just looking to built a semi-capable rig that I can count on. Would the OME choices be a better option if 265s are the max tire? I am worried about their tendency to sag. Looking to do things once and be done.
Well, there it is. Any ideas, opinions or holes in my plan?
Ive got bilstein 5125's paired to the lc coils in the rear and I like it alot. Personally 285/75would be the smallest I would go, especially with the SS lift..
Option two: All from Toytec:
Front:
Bilstein 5100 adj(set at lowest setting) w/ OME 883s-possibly 881s
Diff drop
Rear:
OME 891s
Nitro shocks
Ext brake lines
Followed later by the adj panhard bar from SS.
All with 265/75s.
Thundro
