Quad-Xenon HID Retrofit Project
Damn thats sick...you did all that wow....thats def. one thing i never really got into..was opening up lights...i would love to have a set of those!!!!
Nice retrofit! One question, those projector housings have those hi-beam wires on the back of them, what did you do with those wires since you have a separate low and hi beam bulb?
I wired up a seperate 9005 connector to each pair of solendoid wires and plugged them into the stock connector at the body harness.
Crap, you just lost me there:cry2:
Do you have a wiring diagram?
Lets say I want to do the same thing but only to my lowbeams, do I just ignore the wires on the projector housings completely?
is it me, or do i see that u didnt put on that plastic cover lens back on the signal and parking light. must wanted to remove the amber reflectors i see.
I did a custom wiring harness where I took one output from the factory body harness and relayed it into four outputs for the each projector. I then took the bixenon solenoid wires and wired each headlight's pair to a 9005 male connector. This is what activates the solenoids for the high beam function.
You're right, I left that plastic cover off. I personally like it much better like this. Seems 'cleaner'.
Led turn signals? You must have a led flasher unit? You must do a write up on installing those!! Btw where did you get the bulb for the day lights (light protruding under the signals)?
Great job
and to finish it off, new housings that I bought off of Rock Auto so that I can take my time and do this project right.
Which housings did you get from Rock Auto - seems like they have different quality (and price) housings? Why did you get the one that you did? Thanks
Gives me reason to finish up my new retro too! I've been sitting on all the hardware for my quad setup for like 2 yrs now, lol
In case someone wants to attempt the retrofit! I have a promo code for 25% off on the theretrofitsource.com! IH8MUD25(case sensitive) is the code! Get the D2S mini as the op did or get the morimoto mini H1 like I did! Just wanted to share! lol Code works for your whole purchase!
@ Liqourish - I do have the LED relay installed. I did that like three years ago. The LED's under the projector I got from v-leds and they're the high output singles with the heatsink.
@ BigEd - Lightwerkz didn't do anything, I don't think I even mentioned them in this thread. I did it all myself. The housings I got off of Rock Auto are made by TYC. I think they were like $125/ea. As far as the Sport / SR5-Limited housings go it didn't matter to me as I was going to paint my bezels.
@ KC - Negative, I bought new housings from RockAuto Auto Parts. I wanted this install to be fresh, clean, and new without being pressured for time. Plus the T4R is my DD so I can't afford to have down time with the truck.
New Member, new owner of a used 07 4Runner. First mod that needs to be done is lighting.
I was wondering if you remember which brand/manufacturer for the headlights you ordered from RockAuto? There's TYC and various manufacturer are the only options, my guess is the TYC?
Really appreciate you posting this up, very helpful.
TYC was the brand I believe.
Good luck, you'll love the results!
Did you find the fitment of the TYC is very close to stock? Bought used 07 4Runner, the headlights have some moisture on them, so I'd like to purchase a set to be retrofitted.
Mike, I saw most of the photos before the links were broken, but I don't remember seeing anything about where you mounted the ballasts. Curious where you mounted them.
Anyone else know if it's OK to bake the ballasts (Morimotos) with the headlamp if the ballasts was mounted on it? I'm thinking of mounting them to the bottom of the headlamp, but the screw head would have to be inside the headlamp.
That's where they are on the driver side, but when adding a second set of ballasts, room starts running out quickly.
Passenger side is no problem.
charlesz
