Mike07SE
So a buddy of mine at work was telling me a few weeks back about these new-to-us Mini Morimoto projectors. I looked them up on The Retrofit Source's website and stumbled upon the Retro-Quick (D2S) kit. So now armed with this new discovery and researching and checking out other retrofits, I decided to take this a step further and not only get the kit, but also get the H1 Morimoto to go in the high beam location as well. OK so now I've got D2S Retro-Quick, H1 Bi-X projector, D2S AMP connectors (already have PnP HID kits), H1 HID bulbs from TRS, and to finish it off, new housings that I bought off of Rock Auto so that I can take my time and do this project right. Now on to the pics and writeup:
Headlights already baked and apart (did 300* for 5 minutes plus armed with heat gun). After this point an initial test fit of the H1 in the high beam location turned out that the threaded back would not readily slip into place. Armed with a drill and brake cylinder hone, I worked on this for about 10-15 minutes until the threaded back would go in. Why the hone? A perfectly round hole is acheived giving the tightest fit possible to minimize movement on any axis. I have seen guys on the Dodge forums retrofit with a dremel and the result is what I'd consider a tad sloppy when tight tolerances is crucial at this point. Here is a mock up test fitting of the projectors:
Here's a closeup of the Retro-Quick bracket and Morimoto D2S projector:
Front bezel loosely in place:
Of course now I'm continuing the blacked out theme so I gave all exposed chrome and the projector shroud a shot of matte black texture paint. These look much better in person and the pictures cannot do it justice:
More pics/posts to come...
