Question about air down.
calcrc
Hi guys, I just wanted to ask your advice. We will be going on a fishing trip late May and we will be doing around one hour and a half at least of forest road.
What tire pressure you guys recommend we should air down to ?
Thanks in advance.
Thanks in advance.
20 PSI is a conservative number.
I air down between 20-15 depending on the terrain.
[MENTION=85641]calcrc[/MENTION] the sweet spot will depend on the terrain, your tires, and how fast you want to go, but I usually drop down to 20 or so as a starting point. Have fun!
I typically air down to 15 in most cases, and further to 10 in special cases (deep or icy packed snow).
It depends on the tire, but the lower you go, the slower you should go. Speed creates more heat and friction in the make up of the tire and can compromise the integrity of them.
you shouldn't have any issues on the forest road running regular tire pressure..if you were going to be in soft sand or conditions where a lot of tire patch is necessary I wouldn't hesitate to go as low as 15..I run down to 12 on my off-road rig.
true, but that long on a gravel road, running aired down is usually a nicer ride.
id think 20 would be a good number.
Are running d or e rated duratracs?
Either way I'd save the time of airing up and down on forest roads and spend it catching fish:)
I won't do any less than 15 lbs since I don't have beadlocks. On that road you are talking about, yea probably 20 to 25.
And on another note, Stauns deflators are amazing. More expensive than the cheap ones on Amazon, but I think the quality will keep these working for a long time. Screw them on each wheel and wait until they stop, easy as that. I think they are supposed to be factory set to 18 lbs, mine stopped at 15 which was fine. You can adjust them to any setting you want. I got the standard duty 6-30.
Staun Deflators
I have staun deflators set at 18 and since I"m lazy, thats the number i deflate to regardless of where I go.
I do 15 for soft sand and 18 to 20 for trails. Sofens the ride, easier on ball joints, wheel bearings and you.
I've gone to 8-10psi for years in the sand, I am carefull about not pulling the bead off the rim and I wasn't easy on the throttle either. For hard pack, it depends on the tire. I'd say start 15psi or when the tire visually starts to bulge out.
I hear you guys, 20 psi seems to be the sweet spot.
I will be driving around 45 miles/hour most of the trip. Give or take :)
Thanks for the fast replies.
What is the condition of the forest road? If it's anything like ours here in AZ, I wouldn't air down at all. Waste of time and effort on a well maintained, flat, relatively smooth dirt/gravel road. Also, if you do air down, do you have a way to air up before you travel distance on hardball road or is there a gas station near the end of the forest road?
On a gravel FS road just drop your pressure a little, reducing 5psi should make the ride comfortable
That ^
It really does not matter for forest roads.
Most importantly, most people forget that it all depends on P vs LT in harsher terrain.
YOU DON'T WANT TO AIR DOWN P-METRIC AT TIRES FOR ANYTHING BUT DEEP SOFT STUFF.
1/ They have plenty of flex at street pressures.
2/ They are plenty comfortable at street pressures.
I run Backaway to Crown King, Broken Arrow, Crapshoot, and every other low-end difficult, moderate, or easy trail in AZ or UT at 33 psi.
AIRING DOWN P-METRIC IN HARSH TERRAIN=TROUBLE with sidewalls.
On the other hand, LT tires especially E-load are worthless at street pressure in harsh terrain. At street pressures, they have no flex, and thus have poor traction and they will also rattle your teeth. They must be aired down to around 20 psi or less to perform properly in harsh terrain. At 18-20 they should have great traction and ride very smooth as well.
But, again, on a forest road, the only issue would be comfort.
That ^
If you mean harsh as high friction, I agree, if you mean harsh as questionable sometimes cutting through a soft layer to solid bed is worth some psi...
I deal with a lot of ruts and mud in the midwest, fully understand that geography is the decision maker
Sorry for the generic expression!
The typical Southern AZ terrain, mile per mile, is the same from easy to very difficult trails, aside from the obstacles. It consists of extended sections of broken sharp rock and constant wash crossings and drainages running across the trail. In these conditions, a P-metric tire will expose its sidewalls too much and would also risk a pinch puncture though I am not very familiar with the latter and unsure if it applies to P more than to LT.
Say, Southern Utah terrain can on occasion be similar to Southern AZ but normally you get a lot less broken loose sharp rock to deal with. In SW Colorado, there is a lot of broken rock, too, but the sections are at least very short and very slow speed.
I saw nothing like this in Montana where we drove more than two dozen dirt roads and trails. We did two rocky trails, but the rocks were well-rounded, like riverbed rocks, not sharp rocks. We went through a lot of fallen branches though, at street pressures, and had no issues. So I guess that is the mountain equivalent of the desert sharp rock!
I explore in the Phoenix area
2016 trail with KDSS
265 KO2 C rated
38 psi street
~28 psi forest roads and smoother dirt roads and depending on outside temperature.
That's what works for me, try things out and see what works.
If you have P rated tires, do yourself a favor and get something else.
Sent from my SM-N960U using Tapatalk
Lucky dog! Its wild how lacking the midwest is with true open lands. Have fun and any dont think about your tires so much unless you feel they could be better. I guess I'm saying you may prefer feeling the road more where someone else may want to float all over lol
Personally I'd head out and see then air down after enough time to feel the difference. It will make future decisions easier. I only air down for muddy hills
DJNutshell
