SeattleMike
I'm gonna guess an '04 with the original battery.so, i take it you don't have a 5G then?
So, looks like you can stay in 4WD on both slippery and dry pave? Are you sure you are talking about 5th gen 4Runner TE?
You can use the part time system on dry pavement. Just don't use it while turning. It is best to use it while conditions are slippery though, such as rain, snow, and ice.
There is not a situation where you would need 4wd and could not use the part time system. I really don't understand why people make such a big deal over it.
Pretty much true, but drive train and tire wear increase on pavement and handling suffers on slick so many people like a system where all that can be forgotten about.
I don't see how tire wear or handling on slick surfaces is affected by a part time system.
Don't the full time systems split the power 60/40?
I believe that it varies depending on cornering, acceleration, etc. from 50/50, to 30/70 to 40/60 or something like that....
So it really is no benefit to have the full time system.
So in conditions when true 4wd is necessary you would still have to lock the center differential in a full time system, which would make it the same as the part time system. So it really is no benefit to have the full time system.
I think this is where you're missing the point. Forget about locking the center differential for a moment and think about how a Torsen (torqen sensing) differential works. The beauty of the Torsen center diff is that is can respond to changing road condtions, anything from total grip to zero grip or inbetween. So you can engage the system and be sure that the Torsen (along with help from ATRAC) will send power to the wheels with grip. This is true no matter what road surface you're on and you can use it on dry pavement or any road surface. That's the benefit in a nutshell.
I notice it especially when we have slick roads when it first starts raining, after it hasn't rained in awhile, and the oil in the road comes to the surface. With rear wheel drive it's hard to get traction like from a stop sign/light or making a turn from a stop sign and the back wants to kick out.You know when you have to really feather the gas.
Actually, Torsen is fairly useless when one end has zero traction...this is a weakness of Torsen differentials. It works well in between, as you stated. This is why, when off-roading, it is a good thing to lock the center diff. If one axle sinks in mud, then you will be stuck unless you lock the center diff.
