Question about SR5 fender flare hardware
DavidH.
Member
Do the skinny chrome flares use the same mounting hardware as the black all plastic SR5 flares? Thanks!
The skinny crome flares use those snap in grommets to hold them on. The same clips that hold the plastic fender insert in the front fenders inner fender. Could be the same as the all black not sure though.:)
Also the bottom near the door has 3 or 4 of these screws in row and I believe every other one has a screw with a 10mm head and Phillips head in the center of that 10mm hex head.
I did verify that is correct 4 up in the back and every other one has the bolt screw in it.
Here is the part number for grommet screw. I dont have the part number for the screw handy. I just wanted to make sure I was correct.
The limited flares are hooked up the same way so. I guessing the OEM black flares would be identical hookup if the other 2 are. :)
REE
