Question about tail light, and bumper lights
cdoyle said:
Yep :)
that about sums it up (lol)
What about electric connection? How did you figure out to connect it to existing wire housing? I remember it coming right to the Parking/Stop bulb and then transfers to Turn Signal and Reverse inside the TailLight. If you cut this middle part out, how you connect it to the vehicle? Post some pictures pls. I didn't thought of this method of installation because of the wiring.
WHAT I didn't know that!!
J/K :)
When I cut the center out, I kept that connection piece intact. So now I'm glueing that back into place (plus it helps cover the module.
I'll reattach the blinker/reverse lights wires to those little connection points.
Then I'll just put the main connector back in place, to supply power to those.
For the module, I'll have to tap into the truck wiring to get power.
I'm taking pics, so hopefully that makes more sense once I post the pics.
oh, once the glue dries, I should be able to install this back in the truck tonight :)
Then it's on to #2
