question about toytec 2" BL
thorridder
alright working on the truck a lit today. A lot off the front is off. But I just got my BL and not 100% sure on it. It comes with the 2 smaller ones and not sure if they are for the front or back. Also if you keep the original black ones on it? Or any line extensions? And will figure out the bumper lift later. Help would be nice.
Thanks, chris
what ^he^ said.. :D
I suggest having a friend around to help.. It's 1 man do-able but 2 makes it a lot easier.
a friend and I put my 2" on in like 2 hours roughly. Taking interior apart is a little tedious. Don't forget to loosen the steering shaft and move the shifter lever on the side of the transmission. I can't remember if it was a little forward or backward. Someone will chime in I'm sure.
what ^he^ said.. :D
I didn't move the lever on the tranny at all. I just loosened the nut, put the body lift on, and tighten the nut down back where it was once I was done.
Thanks, chris
As posted above, the smaller spacers go in the front. No line extensions needed. I see you have a manual transmission, be sure to remove the metal divider between the two shifting knobs, or you won't be able to shift into 2nd, 4th, or Reverse.
If you have any further questions, you will get the fastest response by calling us.
Good luck and post pics when you are done!
Ok so small goes on front
Keep the rubber that's there
Something about a trany bolt
Loosen steering
Shifter thing
Is that basically it?
delislerebecca
