Question for Black 4runner owners
swooopeno
I just put my first coat of wax on since buying the 4. I used what I normally use, which works great. It is maguiers (sp?) carnuba liquid wax. The black 4's don't seem to have the same paint protective coat as the other colors. I applied the wax, waited about 4 hours, then buffed it out. I had to buff for about 2.5 hours before the wax streaks went away. Is this normal? Could it be the buffing towels I used???
Does anyone recommend the powered buffers??? Which model?
The Porter Cable is great for polishing and applying wax but I have not heard as good of reviews for the machine to take polish or wax off. I still do the "taking off" by hand.
Make sure you don't have too much wax applied and use a microfiber towel to remove it.
I'm using Meguiars NXT Tech wax on my black 04. It looks great and is very easy on and off. I use a PC to put it on and a microfiber towel to take it off. I could probably do the whole thing in about half an hour if I was rushed.
The tempe was about 90-95 and close to zero humidy (as it usually is here). I waited at least 2 hours before removing it. Should I wait longer??? I didn't wait at all on my last car, and it came off smooth. I can't figure it out.
What you can do when you get streaks or hazing is to get a bottle of water with a sprayer and just mist the surface, then polish it out. The water helps to distribute the remaining wax. Another good thing to use is the Griot's Speedshine.
When i do my truck, I use the Porter Cable to apply the polish and wax. I also use it to remove the polish and wax with the microfiber bonnets. Of course it doesn't get 100% of it off but it cuts down on the elbo-time. Once I get the majority of it off, I use my microfiber towels to buff it down. Where I still have a little hazing/streaks, I mist it with a little Speedshine and she is done.
Thanks for the advice Momo. Hazing is the word I was looking for. That's exactly what happened. I wasn't in the sun at all.
The other strange thing is, the first day after the wax, the entire 4R was covered in a layer of unusually small dust particles. I didn't notice the dust before the wax. Is this the same with you, or just AZ conditions?
This all might be just cause I'm use to a silver car (where nothing really shows up dirty). This black beast is tought to keep clean!
It is just the dried wax that is making the dust. After I get done with all the polishing and waxing there is always a dusty layer on my windows and on some of the surfaces. I just run my California Duster over it and she is done.
The problem I have, living in Alabama, is the high humidity. Before I had my garage, it was a pain because I would have ot find a shay area, but because of the humidity, the wa had a hard time setting up. Now that I have my garage, I can control it better since I have AC.
Ditto
Follow the advice of the wise Momo! Griot's and the PC work wonders!
:guitar2:
044runner4
