I'm a 4Runner newbie; Recently bought a '98 Limited 4wd for my son. Only on the interstate ride home did I notice that what I initially thought was a tire(s) out of balance appeared to be something different.
After reading a little on here, it appears that the vibration/noise above 45mph or so (perfectly smooth when off the gas) might be the result of a bad U-joint.
I crawled under yesterday, and found a great deal of play in the U-joint at the rear differential. Question; I also read on here about a slip-joint driveshaft. Am I correct in understanding that I can take the 4 bolts loose where the shaft connects to the rear end, and then simply slip that end of the shaft out of the rest of the drive shaft?? Does it just slide out?
And then to put it back together, it just slides back in? (I am aware that I need to mark all of those pieces so that they all go back in-line as they were before removal.)
Is it that easy? LOL!
Thanks in advance!
Thanks in advance!
