toytech76 said:Why do you want to prime your fuel system? Personally when I put a motor together. I want to crank it for a little bit before I start it to build oil pressure. Just by cranking it the fuel pump will do its job and fill the lines. If you need to prime the system without cranking it, take a jumper wire and jump terminals B+ and Fp in the black diagnostics box under the hood
