Quick Lift Question
hulk311 said:
$120 is waaay too much for a BL, check with 4crawler.com
I understand that setup is not for hard-core wrangler style offroading, but can that setup handle mild offroading?
Can it handle sand dunes?:confused:
And again, what do you mean by handling sand dunes?
There are far worse things to drive through than sand dunes. You are more likely overheat the engine than break suspension parts. Don't worry about it. In fact, a suspension lift is a great bonus for sand because ground clearance is extremely important.
Suspension and terrain wont cause the vehicle to roll. The driver will. It is up to the drivers judgment as to whether or not he/she should attempt something and exactly how it should be done. For example. You will virtually never roll anything by driving directly up a dune, but if you try to drive across it sideways, then you are asking for trouble no matter what you're setup you have.
Do some research on sand dune driving techniques and you'll be fine.
Dude, sand dunes have never been a problem for our 3rd gen 4Runners. These are some pics back when mine was stock and had AT's on it. s701.photobucket.com/albums/ww20/shawnstcyr
How do you drive around with that sticking out of your roof ?
image.php
I decided to get the following for a lift:
http://toyteclifts.com/index.php?pa...ategory_id=71&option=com_virtuemart&Itemid=53
You've selected a great kit for your vehicle. With the once inch body lift, there are manufactures out there that build after market bumpers ready to bolt up cleanly with a 1 inch body lift on it.. something to consider. Armorology to name one.
