Quick question: 12 acc power supply under hood
catalina34
Installing my turbo scavenge pump. I want it to power on with the key in the accessory position. Anyone know an easily accessible 12v accessory power supply under the hood?
Thanks in advance.
What did you take it from if you don't mind please.
Are you doing a similar Clowmeats rear mount set up? Did you use the same pump?
shayne
I used a different pump. Mine is made by Turbowerx and is a higher end pump. I am doing a rear mount set up as well but our setups have some differences. I ended up splicing into the seat heater at the fuse box. My seats dont have heaters so the pump is the only thing drawing power there. It is powered on by the ignition rather than accessory power which works fine too.
Cool thanks, I'll have to check that out. My seats don't have heaters either, I'm goina poke my head under there and see what's up to get power.
What turbo are you looking at? (last thread jacking question)
shayne
Thread jack away!
IMG013-1.jpg~original
IMG012.jpg~original
I am using a Holset HY35 from a Cummins diesel. It's a very durable turbo that spools very quickly for the amount of air it flows. They are easy to find used and are pretty inexpensive. The one I purchased was already modified for an external wastegate which saved me the trouble.
In the pics I was just making sure the flanges bolted up okay. I'm going to turn the waste gate 180* so it faces the hot side.
