Quick Tire Buying Question
BlackRustBucket
I've done my research so I'm not trying to be lazy...but I'm a little thrown off by what I've read and looking for some clarification. I need new tires for my 97 limited with 16s. I want the largest tire, without rubbing, that I can get which are 32's after researching. HOWEVER...alls I keep seeing is 265/75 this 265/75 that. Isn't 265 the width? Is this in almost every recommendation by coincidence? I want a 32 that will be good in snow so I was going to go a hair skinnier. Could I go bigger diameter with skinnier? (ie 255/85/16) for example? Thanks guys
Yes you can go skinnier and still get a 32", 255/85/16 and 255/75/17 are both 32" tires. I have 255/75/17 tires and I'm really digging them so far
Cool thanks for the info. But your saying 255/85 on a 16in rim is 32? Cause everyone's saying 265/75/16 is 32in. Again I thought there's no relation between the 265 (or 255) and the 75 cause only the 75 corresponds to 32in? I know I'm missing something just can't figure it out
Never mind...the middle number is a multiplier to the first number to get a ratio I see. Only other question is if the tire is skinnier can we go bigger or does the rubbing occur due to more than 32in regardless does anyone know?
Sent from my SM-G935V using Tapatalk
seltzernator
