Radar Detector Hardwire FYI
KDCane
I figured I'd pass this on as it seems like everyone is always looking for the wires to tap when they hardwire a radar detector or for that matter any kind of 12V device.
The way I did my Valentine 1 is pretty similar to everyone else. Ran the power cord up the A pillar and tucked the wire under the headliner, dropping the wire above the rear view mirror. Then I ran the wire down the wire holder for the auto-dimming mirror. Came out pretty good.
From searching the board, the problem most people have is hardwiring it into the fuse box. I found a neat little gadget at Pepboys which should help everyone out. It plugs into a fuse in the fuse box effectively splitting it. Your original circuit is fused with the 'A' socket and the second new circuit (with a 12V power wire coming out of it) is fused to the 'B' socket. I plugged into the ACC fuse, got my power and was done. Very easy.
Here is a picture like the one I found. It was $8.
Way cool. Thanks for the pic too!!! So if you need to, you can go right back to stock just by removing this plug and replacing the fuse? Cool deal....
Yep... Seems to be a great idea. On my Honda S2000, the fuse box had some auxilliary taps so the radar was much easier to hardwire. The truck is totally different.
