Radar detector hardwire
oksailor
Trying to hardwire my Escort but cannot find a good power supply to tap into.
Tapped into something that had to do with the alarm, that wasnt too good.
Can anyone give me some ideas?
I did mine today in my 08 and I used the yellow wire from the compass mirror and a white/black stripe(ground) from the overhead console where the lights, homelink, and sunroof is. I tried a power wire from that same harness and it turned out it was for the tilt up part of the sunroof. So when I turned on the V1 it tilted up the sunroof! HAHA So I moved it to the rearview mirror yellow wire.
thats a good idea. wish I had a V1. Unfortunately, my escort has the remote and the power wire is located near the remote. need to find something closer to the fuse panel
Just tap into the fuse panel. Splicing into another wire may create problems on warranty coverage and the fuse taps work great
They make fuse taps and are sold at auto parts stores. I picked one up at autozone. It's just a big fuse block that plugs into one fuse slot. The block makes 2 slots out of the one and 2 fuses are inserted into the block. A red power wire comes off the block to connect to your device. Then you just mount your negative wire to anywhere that will provide a good ground. Check out the picture, they make these for mini blade fuses and standard blade fuses. I think you have minis.
Important: Whatever device you are hardwiring needs to be able to handle 12V DC. I.e. I had to connect this fuse tap to power a hidden cigarette lighter/power adapter I put under my dash because the device I was wiring could only handle 6V DC. So I had to keep the included power cord for the device and hide everything under the dash. It still gave the look I wanted and made it easier to convert it back to normal if needed though.
thanks a million! Got it hard-wired this weekend. I actually mounted the remote in the accesory panel to the left of the steering wheel. will try to post a picture soon
I tapped into my acc. fuse with a fuse splice and now my rear window will not go down. WTH? Will it make a difference if I flip the fuses? Will try that tomorrow I guess
I would check the fuses first. If those are ok then I would pull out the fuse tap and put back the original fuse just to rule out the fuse tap as a cause of the problem. Mine is tapped into my ACC fuse slot as well but I didn't have any problems.
workingwheelswnc
