Radiator Cover Clips
Jeffrey_VB
Popped the radiator cover off today to install a grill badge. Cover came off ok, but when I reinstalled the cover, none of the 13 plastic clips that hold that cover in place are grabbing, the cover is loose and the clips just pop right out. I was installing by pulling the center out, pushing the clip in, then popping the center pin back in place. The pin clicks in place, but just not grabbing. Are these clips single use only?
No. To remove the cover you press the center in till it clicks. Pull them pin out. To put it back on you pull the center up above the pin. Put them pin in and press the center until it’s flush with the pin
Yep, did those steps, they still won't grab when I pop them back in. Even if I pop them in, without the cover in place, they they pull right back out.
I replaced my clips with some from Car Quest or someplace like that. The old clips did not work right for me either. The new clip have slots so that a clip removal tool can be used to reuse them over and over with easy removal.
I do not remember what size I used but if I recall I had to ream the holes out slightly for the new clips.
I've already ordered some from Amazon. ;)
This has happened on a couple of the fasteners when I reinstalled them, but it was because I accidentally pushed the center pin of the fasteners down when I reinstalled causing them to release.
I prefer these clips but the aren’t “push to release”, you need a flat blade or the supplied tool. They’re a little wider than stock.
Amazon.com
Had also annoyed me about the loose pins on the radiator cover.
Thanks to the detailed instructions I have learned about this push-to-release-pins. I had simply pushed them in too far at first. Push them "flat" an now the original clips hold correctly again.
I found my clips with weathering eventually got brittle and they just snap. Do yourself a favour and buy a big bag of replacements. You can get them cheaper off Amazon, just make sure you get the right size... these things seem to last maybe 3-4 years or less. Less if they get the usual freeze thaw cycle. Also I have found using a small pick helps pop up the centers.
Just replaced mine on my 2018. After a few on and offs over the years they seem to wear out.
The OG shield clips are:
Sight Shield Clip Product ID: 90467-07211
(push to release type)
Fender Liner Clips 9046707201
(will also work, these you need to pry up and do have a larger diameter head)
I've just stopped using them. Probably about 2000 miles ago. I'll check and report if the vibration and friction has caused any issues (I kinda' doubt it though). There's a good bit of compression when the hood is closed.
I just got really tired of chasing them when they fell or replacing them.
