Rake after lift - Billstein 5100 question
JeffMerr
It's been about 2 months since my lift was installed and the front settled with a slight rake. At first I wasn't going to do anything about it, but the rake is starting to bug me lately. I did the Wheelers T1/T12 lift with Billsteins set at 0. I also put a 1/4 inch spacer on the driver's side to correct lean. My question is, if I go up to the first notch on the billsteins, how much lift am I going to get? My rake isn't too extreme, but I'd hate to end up with reverse rake.
Finally got around to taking measurement on a level area. The following measurements are from the center of the wheel to the bottom of the fender.
Front left: 22"
Front right: 22"
Rear left: 23.5"
Rear right: 24"
Not really sure what to make of this considering I put a 1/4 inch spacer on the driver's side front...
Thanks. Any reason why my front left isn't higher than the right even though it has a 1/4 inch metal spacer? Seems odd to me.
the 1/4" spacer is compensating for the lean that is present, the spacer is doing what is supposed to do by evening out the front end.
