random 04 sport edition 4wd questions
what does the X-reas shock system do? & how does the DAC button help and what does it do. noticed hydraulic lines on my shocks. oh yeah what size is the sub on the JBL systems for that year.
The hydraulic lines you mention is the xreas system. Info on xreas: http://www.toyota-4runner.org/perfo...superchargers-more/1076-xreas-suspension.html
Dac is downhill assist. With it enabled, it allows you to go downhill and it keeps you under a set speed without you having to use the brakes. I think the speed is around 5 mph, not sure though as I've never really used it.
The factory sub is 8". More info: http://www.toyota-4runner.org/4th-gen-t4rs/62400-replaced-jbl-sub-added-amp-install-pics-info.html
Also keep in mind the DAC only works in 4-Lo. You don't need to worry about accidentally hitting it while your driving. It's quite nice for going down steep inclines (and scaring the crap out of passengers)
I tried the DAC once just to see how it is. It worked well. Kind of noisy though with all the ABS stuff kicking in. But it worked.
I like the xreas system on mine but if it goes bad I'll probably scrap it and replace with a Toytec system or something.
i count open the link for the Xreas system. :\ guess internet is trippin.
