Random squeaking?
deedst4r
As i was driving yesterday (in silence) I noticed a squeaking coming from the rear passenger side. It may be inside but i think it is coming from the outside. It only makes the noise while driving at random times. Does anybody know what this could be?
I know this is a minor "problem" but I would like to get it taken care of. Thanks for the help y'all.
-Joe
That may be it, so i will try it out. Where should i grease the seats? And with what to grease them?
Where was the spot that squeaked on your seats? I am having a hard time locating where exactly the sound is coming from.
Hi Joe,
I had something similar with my truck last month. My random squeak came from my ebrake assembly. I guess I had (or more than likely my wife) had set the ebrake and drove off one too many times. It twisted up and eventually snapped a spring and end cap that was holding the spring in place. The cap and spring eventually wedged themselves between the ebrake pad and the rotor. At first is was a really really light squeak only heard around 5-15mph but eventually I started hearing all the time. Not sure if that's what your issue is or not but thought this might help narrow it down.
Woody
Are you sure it's not your brakes or calipers? I had a rock stuck in mind that was squeaking, driving me insane. Wound up just being a a little rock.
I have a squeak from the rear brakes too, only when very cold and the first few starts, I think its the parking brake though, because it doesn't do it if I put a little pressure on the parking brake pedal.
Update: Squeak gone since 120K service. Don't know what they would have done to the rear brakes..
patnewton
