“Raptor” amber led mod writup (06-09 grill)
Johns06yota
Member
I had seen several posts on the raptor led mod with a big variety of how people put everything together both with the location on the grill as well as the model year of 4Runner. This writup is for the 06-09 grill as I could not find a writup for those model years. The supplies you will need are as follows:
50 ft of 18 gauge red/black wire (Amazon)
Amber led strip 2x (Grand General 77650 Amber Thin Line 6-LED Marker and Clearance Sealed Light)
Fuse tap for my application (mini fuse APM)
Wire loom (25ft - 1/8 inch Flexo PET Expandable Braided Sleeving – Black – Alex Tech Braided Cable Sleeve)
Switch (Cllena Toyota Blue LED Push Switch with Connector Wire Kit Laser ( Driving Lights)
Useful tools:
Soldering iron
Heat shrink tubing
Tessa tape
Things to note: I had seen this mod where people had tied it to either the daytime running lights or marker lights for night time but I didn’t like this option. I wanted to be able to use it whenever the car was on but still have the ability to turn them off with a factory looking switch. Also the wire loom I used does fit but I think if I didn’t it over I would have gotten 1/4 inch tubing instead.
I currently have wired everything up for install and will add more information tomorrow when I put it all together
Looking forward to the final pics. This mod looks great on 5th gens, and I always wondered if it would look good on the 4th gen.
Nice. I’ll be following your progress too, as I’ve been contemplating doing this for awhile to my’04. I was thinking I’d tap into the marker lights on my ‘06 headlights, but as you mentioned, it would be nice have the option of a switch if I didn’t want them on for some reason.
www.toyota-4runner.org/4th-gen-t4rs/256079-raptor-grill-5th-gen-marker-light-mod.html
Here’s the way I did mine. I’m excited to see how you skin the cat!
Appreciate the replies! I just finished everything up and am going to post the rest of my writup. I have to give credit that I got the idea after I saw Whytey's '07 V8 SE Build where he did the same thing (also Simple yours looks really good!)
Install writup
I just finished everything up and thought I would share the results. I like the look and the fact that I can turn them off is really helpful. First off I began by securing the leds to the grill. I did this with black zip ties as they were the easiest to work with. Next I routed my wire harness I made up the side of the grill and down behind the hood insulation. Then ran the ground to chassis and the positive into the cabin through the firewall. Next I took the other wire harness I made and ran the wires for illumination to the 115 volt outlet and then ran my hot wire to the fuse panel where I tapped the cigarette lighter fuse and then used a 7.5 amp fuse for the new circuit. Next I ran the other wire that came off the switch to the power wire I brought through the firewall. Next I reinstalled everything and am enjoying my new mod! Will be posting night pics once I get the chance later today
More pics
So this is off-topic, but can you post some photos of the cut off/review of those headlights you're running.
They look sharp, but I want nothing to do with them if they're unsafe for other drivers on the road.
Thank you!
Thank you!
hey just to save you the headache I would not buy these headlights. The cutoff line is pretty decent. I adjusted them down so that the light output is lower. and they look great. In regards to quality though I have not been impressed. These started leaking pretty soon after I bought them and after roughly a tube of black caulk on the passenger side and a little on the driver side they will still fog up a little if it has rained a lot. also after only a year the rear headlight boots have started to dry-rot so i may be replacing them later this year.
Midnight runner
Finally got some decent pictures for my post lmao.
Interested in installing these on my 07 limited. For some reason none of the photos you've uploaded are showing up properly. Think you could check those links and see if theyre still good?
Jhunt
