Re-greasing front wheel bearings?
nobb
I am going to be replacing my upper and lower ball joints, so I figure while I have the wheel off, maybe I should also re-grease the front bearings as a maintenance thing.
From my understanding, there are two bearings on each side. An inner and an outer. Both bearings also have a corresponding inner and outer seal. I am just wondering if there is a way to remove these seals without damaging them such that they can be re-used? Or is it sufficient to attempt to re-grease the bearings in-situ without removing the seals?
wheel bearings are sealed. They do not need to be greased.
If they need grease - they need to be replaced.
2001ATL
