Reach Unmatched Distances with Vision X’s new XPR Long Range Light Bar
Vision X Introduces Ultimate Distance XPR LED Light Bar Using 10-Watt LEDs
May 7th, 2015 Auburn, WA –
Continuing with the mission to revolutionize the lighting industry, Vision X Lighting is proud to announce the XPR LED Light Bar. Utilizing top-binned 10-Watt LEDs and large proprietary 1.5” diameter IRIS Reflectors, the XPR Light Bar is capable of reaching distances of 2,080 feet of usable light (51" XPR-27M). This unmatched long-distance projection is also accompanied by precisely tilted IRIS Reflectors that create a unique combination beam pattern to provide even more visibility at the road’s edge.
The XPR features a new lifespan boosting heat sink design that utilizes deep horizontal fins within the high-quality aluminum housing to dissipate heat produced from the high-powered 10-Watt LEDs. Whether it’s a desolate frozen road in Alaska or on the race course in Baja, off-road champions and transportation professionals alike have relied on the XPR technology to exceed their demands in extreme temperatures and rugged terrain.
The XPR Light Bar is available in eight popular sizes: 6”, 11”, 25”, 30”, 35” 40” 46” and 51”. Each comes complete with a wiring harness for a quick installation. The XPR also features Vision X’s strong Lifetime Warranty to ensure craftsmanship, durability, and dependability for many years to come.
The XPR includes multiple mounting options in the box. Choose from Vision X Lighting’s patented bottom feet mounts that absorb vibration via rubber inserts, or use the included aluminum side-wings with rubber grommets and firmly mount to the light bar with two bolts on each side. XPR owners can also opt out of using the side-wings to directly end-cap mount the light bar with End-Cap Bolts sold as an accessory (XIL-PECM [9889191]). These mounting options allow you to utilize the XPR Light Bar in almost any application without the need for additional parts.
The XPR can also be used in many of the existing Vision X Vehicle Specific mounting brackets, such as the Jeep JK windshield mount, or the Ford Raptor bumper light bar bracket.
XPR LED Light Bar Features:
  • Dual Mounting Options – Patented Feet Mounts & Side Wing Mounts
  • Leading Light Bar Series For Long Distance Projection
  • Precision Tilted Reflectors Create Mixed Beam Spread
  • Integrated Electronic Thermal Management
  • Proprietary Long-Range IRIS Reflectors
  • Plug And Play Wiring Harness Included
  • Latest 10-Watt LED Technology
  • Polycarbonate Lens
  • Lifetime Warranty
Total Automotive Performance is your best source for Vision X & general LED lighting. Call 702.979.1577 or email us at [email protected] with any questions or to discuss a custom tailored lighting setup.
Is this bar's light just more focused then their other 10 Watt bar?
I was thinking of going with the VisionX 10 watt bar that they already have to keep things slim up on the roof.
But at the same time time I am thinking for the roof I would go with the 5 watt (Xmitter Prime?) bar in a 40" with a 40 degree beam for flood light considering I have the spots on the ditch brackets.
Uses updated LEDs as well as a new proprietary 1.5” diameter "IRIS Reflector"
The Iris reflector is designed for maximum distance, but also has a "tilted lens" design that gives it decent side coverage. This type of lens is going to be for more highspeed offroad use, if you are doing sub 60mph offroading at night, a combo beam pattern might be better for you especially as you have the ditch light spots.
The Xmitter Prime has a totally different output than the bar above with the 40 degree optics you mentioned.
Here is the 10" XPI output.
Very cool. Guess I will go be going with the Xmitter Prime when the time comes. Thanks for the info.
I will be contacting you guys at that time too.
Awesome! We are direct distributors for Vision X, Rigid & Baja Designs lighting so we can definitely get you setup with a sweet lightbar along with a T4R hookup price :)
