Rear Axle Seal: Suggestions?
Looks dead nuts on. Nice work. Did you use oem seals?
Dont they use Litium grease in the wheel bearings. Looks like you used mobil1 grease. Im not a fan of the mobil1 grease. It separates and dries out.
Yes Sir OEM all the way!
The grease is Valvoline
If someone is interested
Seal 90310-50006 ($5.50)
Bearing 90363-40020 ($53)
Retainer 42423-20010 ($9 each)
C-clip 90520-36045 ($1)
O-ring 90301-88077 ($2.50)
[Didn't install but the ABS ring is 43517-35010 $27]
I test drove the truck: The straighten up ABS ring is functional..
If an aftermarket retainer [especially TIMKEN (embossed)] is installed, before removing the ABS ring, grind the retainer. The OEM has nothing embossed.
The other side is good and no play in the oem bearing (214K miles): Should I replace that or leave it alone until it leaks? I don't want to experience a faulty bearing in the bad way.
Thanks guys!!
Good job! I bent my ABS ring slightly by not paying careful enough attention to the bearing splitter on the first side. I did better on the second side. It has not been any issue for me in a lot of miles since.
