Rear bearing and seal kit question
You could always try asking the seller. You should also check to make sure it’s the updated inner seal (Toyota 90310-50006).
I just used the Marlin Crawler kit and bought the updated inner seals from Amazon. Everything is working great.
Just making sure this will work for my 2000 limited 4x4 with rear locker..
OEM KOYO Rear Wheel Bearing W/ ABS Skid Control Ring Gear For Tacoma / 4Runner | eBay
When i look those koyo bearings up on amazon, the filter says it won't fit mine with ABS. Granted that's just the bearings but I'm not seeing them with a compatible bearing outside of the oem. Thanks in advance, Tim.
That looks like the bearings I used when I replaced mine. If you are using a press you can reuse the abs tone ring. You only need 2 new retainers as well for where the inner axle seal rides. You can reuse the retainers by the bearing.
Thanks for the replies, I had already sourced Toyota seals but wouldn't mind having an extra set. One of my tone rings is buggered from previous owners time. Probably still works but I'll replace it. I've watched Timmy's video and will be patronizing the eBay guy he recommended for the axle tool.
ghengiskhan
