Rear Bearing Puller/Press Tool Loaner Program
Might have to take advantage of this soon.
Just got some new Bearing Retainers machined and want to see if it will help with the axle seal failing.
Have you tried flipping the bearing retainer that the axle seal rides on and doing a grease/sharpie test to verify where it is riding?
I've flipped the retainer, and it still leaked.
That's the reason why I had one machined. Hope to install it soon and if it works to mass produce it since I already have the provisional patent on the design.
But did you do a grease or sharpie test to see where the seal was riding? That's the important part.
Grease tested it, and lasted about 6 months and leaked again.
I even bought the bearing holder (Cup looking thing) brand new. Axle is straight, no Diff issues.
I will post up results and pictures of the Retainer prior to install.
I’m definitely curious to have you report back after installing a larger diameter retainer that makes a stronger connection with the axle seal??
Update 10/21/2019:
[MENTION=319302]Bad Luck[/MENTION] got the tool back to me since I've not had any other requests. He added a 4"x4" plate along with some PVC piping to help with all the press work to make it more of a complete package.
He's a stand up guy! :cheer2:
Cheers
Update 10/21/2019:
Cheers
It's the least I could do for you letting me borrow the tool! Saved me a boat load of $$$!
This is so awesome! I was just about to go buy one of those tools on ebay to do my upcoming bearings/seals. Just got the shop press put together this past weekend and about to order all the parts. Do I just pop back on this thread to make a tool request when I have everything ready to start the job?
This is going to be headed out to [MENTION=154567]Killer Squirrel[/MENTION] this week so he can get his bearings/seals done. I've updated the spreadsheet.
Would Like to Get in Line
I've followed this forum for several years and just joined. Have a 99 v6 SR5 with a badly leaking axle seal on the left rear and need to replace the bearing (will do both sides).
PM sent.
Thanks a million for this program and for the forum!
Thanks for the quick turnaround on getting it done [MENTION=154567]Killer Squirrel[/MENTION]. [MENTION=451454]Phred in Bend[/MENTION] is next on the list. I'll update the Google sheet and PM you his information. :guitar2:
[MENTION=154567]Killer Squirrel[/MENTION] has sent it off to the next user [MENTION=451454]Phred in Bend[/MENTION]. [MENTION=451454]Phred in Bend[/MENTION], I'll PM you the tracking information shortly.
I've updated the Google sheet.
:pop2:
weekendclimber, you are a legend for making the tool available! As others above said, a deposit might be a good idea to make sure it doesn't wander off. (Also, if you kept a few bucks for the administrative beer fund I would be totally cool with that.) :beer:
Add me to the list please, I've been driving around with no rear brakes for too long now..
As much as I'd like to add you to the list, I see that you're up in Canuckistan. I've not checked postage for sending it up to the Great White North, but my inclination is to keep this going in the lower 48. Not that I have anything against our brethren up in Canaderp, but unfortunately I may not be able to accommodate you. If you can PM me your address, I can check and see if this is going to be an issue. :cheers:
Cheers
No worries! I live close to the border, and have an address in WA for receiving packages. (We mostly like to huddle along the 49th parallel for warmth anyways. :canada:) I don't want this to get pricey or complicated for anyone. I'll PM you my info. Thanks again!
Edit: I PM'd my info, but it doesn't show in my "sent messages" folder... Let me know if you're not getting them.
Got it. Shoot, I could just drive it to you, lol. I'm just about an hour South of you along I-5. I'll get you added to the list today. [MENTION=451454]Phred in Bend[/MENTION] currently has it and I know that given the holidays it will be a bit before he's done, what with family and traveling. You are next in line though :banana::banana::banana:
