rear coils ome 895E????
Brayt4r10
Im about to pull the trigger on some new rear coils, i want a 1 1/2 inches of lift so looks like the only options are saw a way and Ome 895E any one have experience with either coils? Is the SAW really worth the extra money, keep in mind i am of the smooth ans paved quite often, and how well will the ome performed compared to stock?
I think the Sway-A-Way springs are probably what you are looking for if you want a smoother ride. I believe the 895e springs are ~260 in/lb, whereas the SAWs are ~215 in/lb, so the SAWs will likely be a lot smoother if you don't have any extra constant weight in the rear (steel bumpers, cargo drawers, etc.)
From what everyone here has told me, the SAWs will net you ~1.75" lift after it settles; and if I recall correctly, I think the 895e are closer to 2" mark.
Unfortunately, I can't give you any hands on impressions since my SAW springs are still sitting in the box; but I did do a lot of research, I swear :)
Whether or not it is worth the extra money is really up to you. Sway A Way is a very well known company if that's what you are asking, and so is OME; neither is "better" than the other, so just pick which ever one meets your desired criteria.
if you wont put much weight at rear, most likely OME 895E will settle at over 2" height.
i was expecting 1.5", but afterward i like the look and ride
where did you get your SAW springs, and do you know the part number. Would be interested to see what the actual lift would be
I got mine from Metal Tech, but Wheeler's Off Road also carries them. They are both sponsors of this forum as well, so you can find their contact info on the home page in case you are interested.
Thanks for the info. I just pulled the trigger on the SAW 1.5" rear springs from wheels offroad. I also got the Bilstein 5100s for the front for now, and will be setting them at 1.75" position.
Anyone here have SAW rear springs with OME 60080 sport shocks?
i'm looking for a more leveled look since I have OME 884 in the front. Don't know if I should put SAW or OME 895E in the rear.
Any pics with OME 884 front and either SAW or 895E rear would help.
goddesszilla
