IanB
Thank you, do you use the 75w-90, I believe I saw 80w-90 was for the front. Or is it preference since it says only sae 90?
I used all synthetic 75-w90, front & rear diffs, and transfer case.
X4...if I had not done this I would currently have no fluid in my front transfer case. I got the Amsoil. Severe Gear oil from NAPA fyi. Auto Zone, O'Reilly, Advanced Auto Parts, and Pepboys did not carry the Amsoil.
The only way to get AMSOIL is through an independent dealer such as myself or through a retail business who's sponsored by a dealer. If you're interested in buying AMSOIL and having it shipped directly to your home for the same price dealers and retail business can buy it for then send me a PM and I'll tell you how.
So is my NAPA sponsored by a dealer? That doesn't make sense, either way I guess it doesn't matter bc I can get all types of Amsoil from a NAPA 10 minutes down the road.
Thank you guys for all the help! If the bolt is too rusted is it okay to try se pb blaster or something to get it off?
Also I'm seeing that everyone is using 75w-90, is that the same as sae 90?
One consideration, as I just did it myself: the front diff drain valve is an allen key type bolt (plug), and if overtorqued ever, is impossible to remove w/out stripping. I would Kroil the hell out of that one for a month in advance :uzi: then night before, Kroil and immediately cover w/ axle grease, allow to soak overnight, and STILL have a bolt extractor ready! (This method worked great for a stubborn fuel filter on my '01 SR5)
Allen key??? This is supposed to be a 12mm. Maybe the previous owner changed it?
Someone please confirm this is a 12mm bolt/plug. Thanks
Mine drain plug takes an allen key. I could not get the drain loose but could get the fill plug off. I stuck my finger in there and the fluid looks brand new still so I didn't mess with it. I could pump it out and refill but I figured it was pointless and had a million other things to do at the time.
It may have been changed before my brother bought it and he only used 4wd like 3 times.
