Rear door window exterior rubber (Not rear hatch) replacement?
Quiero
Please excuse me as I did a search but nearly everything refers to the rear hatch/lift gate.
My 07's passenger and driver side rear door exterior rubber weather stripping has dry rotted and failed. They dont leak water inside, but I'm worried about them leaking in to the door. These are the "scrapers" on the two rear doors.
Does anyone have a part number for these, and how difficult are they to replace?
Thank you
Looks like 68163/68164. Check Here. This is for an '05 so, you might want to double check for your year. Also, try checking Amazon once you have the part number.
Thank you
Just an FYI, these outer bottom window weather strips aren't design to totally keep water out of the door, they're designed to keep debri out and to sorta clean the window, they do however keep the majority of water from getting in the door, but water will still get in the door/s, all of the doors and hatch have drain holes in the bottom, there's a plastic insert in each hole that allows water to drain but keep bugs, small critters from entering, these drains need to be check from time to time to make sure they haven't clogged and not allowing water to drain out, they can be cleaned but if you have to clean them you most likely have debri in your door/s that also needs to be cleaned out so the drains don't clog again.
charlesz
