Ukie
Having two technology savvy kids (4 and 10 yrs old) and using 4Runner on longer trips I thought there should be a way to keep kids busy on those rides. Unfortunately “Rear Seat Entertainment, DVD Electronics” aka DVD player provided by Toyota (PT900-00101 and PT900-01100) was rather limited and outdated solution, so no go for it. The same story applies to other aftermarket DVD players. I wanted something portable to be used outside 4Runner, and something we can enjoy outside a car.
Seeing how kids were using their iPods obvious solution was to go "larger" and allow kids to use iPads. So I started research on head rest mounts for iPad. I wanted to avoid any kind of ‘strap’ mounts, and I was hunting for a mount with the following features:
- Easy to operate.
- Easy to remove case with an iPad. Need this feature to remove iPad from a vehicle or hide it away.
- Clean mount look when iPad/case is removed.
- Using case as a stand outside a vehicle.
Somehow I came across two headrest mount I really liked: inCarBite headrest mount and something marketed by BMW as a ‘travel system’ with a nice functional iPad mount. Unfortunately BMW stuff was not on a market yet, so I started with inCarBite headrest mount.
inCarBite Headrest Mount
incarbiteusa.com
inCarBite manufactures couple different models of headrest mounts: standard, powered, powered with infrared audio transmitter, powered with infrared + FM transmitter. Basically 4Runner/iPad setup doesn’t need infrared or FM transmitters. 4Runner has Bluetooth to stream audio through a head unit/car speakers. Also there are plenty of choices of Bluetooth headphones to be used with iPads.
Powered option seemed to be a nice one (you can easily hardwire a headrest mount, hello Antman!) but has one huge disadvantage: it doesn’t leave ipad’s 30-pin connector open. An extra 12DC power supply with a barrel plug is required to charge iPad without removing it from a case. It’s a big no-no. I already have plenty of tiny USB wall chargers and introducing another charging interface (bulky 12V/barrel plug) just doesn’t make sense.
So a ‘standard’ inCarBite headrest mount was a way to go!
inCarBite headrest mount is very sturdy. It’s very easy to slide case in/out and tilt it. Even 4 years old can do it. And it’s pretty much one hand operation for an adult.
I've bought my inCarBite mount straight from incarbiteusa.com and spoke with Tim couple times. He's a nice guy and it was a pleasure to do business with him.
- Easy to operate.
incarbiteusa.com
