Rear LCA Bolt Sizes Please
psraff
I'm off buying hardware and I can't seem to find the bolt sizes for the Rear LCAs....
I just bought a new set from Toytec, but I would rather not reuse the hardware (or at least have a backup if I mess one up).
Thanks!!
PS, it was like Christmas. New HID Bulbs, New Adjustable Rear LCAs, and new LC Shocks for the back end.
Thanks!!
I believe it's a 14mm diameter, and something around 80-85mm long would be long enough.
I know the bolts that I'm using are 9/16" (won't work for you), and I had to drill out the mount by a 1/16". A 9/16" is .56", and a 14mm is .55". The width of your bushing should be 2-5/8" which is about 67mm. Getting an 80mm length bolt will give you a little over 1/2" of thread, and an 85mm will give you a little under 3/4".
Great thanks! I knew it would be bigger then a 1/2", 13mm but that's all the info i had.
Sent from my SM-G920I using Tapatalk
M14 x 1.50 (fine pitch). About 93.5mm from under the head of the bolt to the tip (or 89mm from under the captive-washer to the tip). Tip is unthreaded, so more like 87mm from under the head to the first thread.
Thanks guys!!! I went and picked up some. They had either 80mm or 90mm with the 90 a higher grade. I went with the 90mm, but it turns out I didn't need them. Mine came off great and just threw them into some Kroil till I needed to reuse them.
It's always good to have a backup set, just in case!
I pick mine up at my Toyota stealer..... 12$ for a nut and a bolt .....:wtf:
But it's an original....
My dealership is 2 1/2 hours away and cost a third more then what you paid.......
Jkmazon
