Rear lift shock options
CollapsedNut
Hey guys. There is just soooooo much info about the shocks and I'm digging through everything but I wanted to see what you guys are running in the mean time. I have a 1.5" daystar spacer on the rear, plus I use air lift 1000 bags for load hauling when pulling a trailer. The stock shocks are just too short for this, I top them out every time the trailer bounces, and that can be bad cause once they reach max extension the next thing to come off the road is gonna be the tires...and if that happens pulling a trailer it's gonna be a bad time. I ordered a pair of Pro Comp ES9000's #921513 as they were listed on pro comps site to fit "2.5" lift rear" but that is VERY WRONG. They are actually shorter that stock shocks by several inches. With stock shocks I have about 1" of travel before the shock can't extend anymore. Surely someone else has had this problem?
Nobody?
Well, here's what I found. There's a lot of "it should" and "pretty sure" on the internet but I started looking at numbers. The 921513 I had ordered is listed as extended length of 21.75" Stock shocks extended length is 22.3"
The Pro Comps that ToyTec sells as extended length, I'm still trying to figure out the pro comp number on. Possible 924514
Are you guys seriously running stock shocks with your daystar 1.5" spacers on the rear?
