Rear Mud Flaps - Will 14+ Limited part fit on Trail/TRD?
Jetboy
I'm tired of ripping off my rear mud flaps. They're expensive. And I've done it a few times now. I like having flaps - but want something I can cheaply make to replace the flap part and be removable so I don't keep ripping them off.
The limited has no visible flap hanging down. But the missing flap means the rear fender liner is incomplete. The flap also makes up a big chunk of inner fender liner. I'm curious if this part will replace the OEM flap like the limited model uses and fit on the Trail/TRD rear bumper. Has anyone done it that I can't find searching?
TOYOTA OEM 14-16 4Runner-Mud Flap Splash Guard Right 7662535250
They will not fit. I tried the exact same thing. They look identical, but once you hold them up to the Trail mud flaps you can see the Limited ones are wider. The top 2-3 holes line up. The bottom ones do not. So I sent them back.
Unless you can find something else I couldn't I'm guessing it's cut the stock ones.
Thanks!! Exactly what I was looking for.
Crookedcat
