Rear Seat Leg Room: w/3rd Row vs. w/Slider
LongBallLarry
According to Toyota's site, the rear seat leg room is equal when I compare SR5 with LE. Problem is that I do not know if they are measuring given the two options of 3rd Row or Slider.
4Runner with 3rd Row allows for rear seat to slide but Slider equipped models do not slide, correct? Regardless, does either option allow for more rear seat leg room?
Zidaro took some pics when he got his 4Runner with the third row. In the pictures in this post you can see the second row slides forward to allow more leg room for the 3rd row, but not backward. This would leave the max second row leg room @ 32.9 inches.
So you believe that 3rd row and slider equipped models both have equal amount of max rear leg room?
If by "rear" you mean the row behind the driver's seat, yes. I have a sliding tray, and I know that the number is correct. In models with a 3rd row of seats, the second row slides forward to provide leg room for those in the third row, but they do not go any further back than the 32.9 inches listed.
You also lose cargo area height with the 3rd row. Not much, but I would think it has to be considered.
Yes, when I say rear, I am referring to 2nd row. The 3rd row is not important to me but 99% of LEs in L.A. come equipped with 3rd row. I rather have an extra $900 than the 3rd row. If there was a significant rear leg room issue that comes into play one way or another, I may have changed my view.
I am aware of the higher cargo floor area with 3rd row, which is not helping the case of buying a model with 3rd row. Thanks for the link and info.
Rear seat leg room
I have an '06 Limited and thinking of moving a few years newer. Rear legroom is my issue. The '06 specs state 34.6" rear seat leg room; an '12 has legroom down to 32.9. I want more rear legroom not less. Am I missing something? May have to stick with the older model.
Go to a dealer, get your front seat comfortable, and hop in the back of each truck. There isn't really a standardized way of measuring legroom (Ford moves the front seat between measuring the front and rear legroom, for example). I haven't been in a 4th gen for ages, but I feel like the interior of the 5th gen is more spacious. I'm not a tall guy, so I'm pretty comfortable in most cars as far as legroom goes.
^^Yes it does, thought it was cool but haven't used it.
I don't think you gain any leg room unless front seat is moved up.
You'll just have to head to dealer and take a seat.
What Quentin said, and then compare headroom with and without sunroof.
I preferred the rear seat of the 4Runner over all other reasonably priced 4WD or AWD vehicles available in the summer/fall of 2012 (so now BMW, Lexus, Infinity, Land Cruiser).
I suggest you go to the dealership and have it checked yourself. The 3rd row is for small people (4'5"ft under and 100lb under).
I added 3rd row seats to my SR5 P at 140k miles for more passenger seating. Lots of parts and fairly simple.. but yeah its tight for adults and the seats dont recline.. not a lot of air flow either.. but rear window goes down so that helps. 2nd row seats slide forward quite a bit so its doable for a 3 hr trip for adults but wouldn't want to be stuck back there longer than that!
I have an ‘18 SR5 with 3 row. 2nd row seats slide and recline. The seat bottoms do not flip forward when folding as they do with 2-row models. There is some space, maybe a couple inches to the back with the raise in the floor, behind the 2nd row seats when pushed back to their maximum.
I’ve used the 3rd row only once, that for a small adult man and a child. I personally cannot access the rear seats; too old, not too limber. There are two individual seats, one can still be folded while the other is in use. When the 3rd row is in use, there is virtually no room between the seat back and the rear hatch. I had to empty the cargo area and leave behind all my usual carry ons (extra water, a jump start pack, a small to-go bag) as well as my cargo mat and privacy cover.
To see how much space in the cargo area that you loose, check out one of the 3rd row delete threads. With third row, the cargo floor is several inches higher and even with the lip at the rear. That allows things to roll out and fall to the ground if you are parked on an incline. I found that out the hard way when I first bought the rig and lost a 1.5L bottle of Jim Beam … :crybaby: I solved that, somewhat, by purchasing the Toyota cargo net that runs across the hatch opening. It doesn’t stop things from rolling out, but since it mounts folded in two, it creates a full length pocket to hold things.
Note that if you purchase privacy covers and cargo nets that designs and part numbers are different for 3 row and 2 row models.
