Rear suspension air bags
wildcatt
Im thinking about going with some rear coil airbags and was wondering what if any thoughts people had about them.
Ideally I would install and only use when hauling a load.
Can you just leave in a neutral pressure when not required, or do you have to have a small pressure all the time.
I read you need to cut the coil bumper stop off? Does that cause any problems?
thx
THose bags will definitely work for your intended purpose of hauling and such. My brother has 'em and the only time he ever inflates them is when he tugs his camper. There's no issue with them being un-inflated IMO.
Yes you need to chop down the height of the cone bump stops otherwise you won't be able to fit it the air bags, fittings and hose that goes on top.
I run the Firestone bags in my truck and have been really happy with them. Just make sure that if you're lifted you leave some extra bumpstop in there to compensate.
I can send you pics of my I install if you'd like as well
premiumusedautoparts
