Rear Suspension Question.
johnnytoofye
Just wondering out of curiosity how bad is it that I'm running a rear suspension that's Bilstein 5100, Toytech Superflex HD, and Daystar spacer? The shop I took it to put the rear spacer on both sides instead of the driver side. I don't do any wheeling or anything. Just normal city/highway driving.
Bad as in is it not okay to run a setup like that.
If by "OK", you mean "safe", then yes. As long as everything was installed correctly, it should be safe, save for center of gravity being a little higher. I am assuming though, that with both spacers on, your Runner will probably have a slight lean down toward the driver's side. Also, your rake will look a little bit steeper. If you are OK with these circumstances, than you are good to go.
Beauty is in the eye of the beholder.
