Rear Sway Bar Bushing/Bracket
Volley
Ok is there some sort of magic trick involved to get these things installed? I am trying to install my passenger side bushing/bracket and can't for the life of me get it to "close" enough to get the top bolt to reach. Any tips?
Volley
PS. I am lifted if that makes a difference (see sig) and I have tried unhooking the end links for movement...
Volley
Undo the lower bolt to allow reach for the top bolt.
Just don't undo the lower one completely. I believe that's what I had to do to get mine installed.
I had that problem as well. I just loosened one side, then laid on the ground and pushed the other side up till it reached. It was a task, but worked. I'm lifted as well for reference.
I use channel locks clamping it tight in one hand while I thread the bolt and tighten it with the other hand.
Takes some determination though, lol.
Hells yea it takes some effort! Thanks for the input all at least I know I'm not the only one!. Will break out my Hulk arms this wknd. And yes I have new links on the list for my next trip to Napa.
You can also buy front sway bar links for a 96'-02' and put them in the rear. They are 1 inch longer and work perfect if you have a lift.
Ambrose67
