rear upper and lower arms bushings
TAB-164 Upper control arm bushings
And complete upper arm
Dude. Killer work. I wish I had checked Amazon before I spent time and money at the junk yard for junk that doesnt work.
Its kind of disappointing I spent 30 dollars on bushings to take care of a arm and new they were only a few dollars more.
I ordered the complete upper arms a few days ago. My off stretch is only 4 days this time. I may not get them before I go back to work.
With the ZN185 in the part numbers I'm pretty confidant they are correct for the 4Runner.
The 4runner is down for a bad front crank seal leak. Pennzoil Ultra must have really cleaned it out. Within a week of getting it and changing oil it started leaking.
Just received the new upper arms. Look good.
Yeah. They do. Any chance you could measure the center-to-center of the bolt holes on those guys? I may in to ordering them if they are the same length as my current ones and not shorter like the ones I pulled off of the 97 at the junk yard.
Mine are probably the shorter length.
The longer uppers may give me a better pinion angle. The shorter ones probably got replaced by the longer ones.
the rear upper control arms on the 2WD units are shorter than those on the 4WD units. the 2WD rear UCA is the same as that used on the LC95 playdo.
<img id="ums_img_tooltip" class="UMSRatingIcon">
That good to hear. I'll hopefully find out this weekend when or if I get time to put them on the 96 puppy hauler. Then I'll report.
I finally got around to replacing the arms. It didn't go too bad. The upper arms were the same length as what I removed.
My lowers didn't have the triangle piece like the ones I put on.
How does it drive? Don't know I'm not telling the wife I did it to see if she noticed the change.
re:control arms.
I called and tried to order the complete upper control arm and they don't sell the complete arm ass. With bushings. Was anyone able to get the complete arm? I had to order the bushings only. Hopefully they come with bolt sleeves as mine are gone. I saw Dan har photo of his on fed-ex box. Is that just repainted or did you get whole arm sent to you. Where from?
I got the hole upper arm assembly from amazon.
I just searched amazon and only the lower complete arm is available.
0125-KZN185L
The "L" is for lower. Replace the L with a "U" and its the upper comete arm assembly.
upper control arm
Well I received lower control bushings today all 4. Only 2 upper control bushings but I was charged for 4 from febest.all 8 for 95 $ includes shipping. Talking to thm is a real PIA. Rafael dropped my call 4 fkn times spelled my name wrong woulent send receipt, couldn't complete order. Bushings look good though. Came with bolt sleeves installed.
So they sent me the last of my bushings friday. The 2 they sent last are different. Will post picures eventually. These have a thin rubber bushing inside a metal sleeve wth a bolt sleeve in the.middle. on the diagrams on Febest website and on the boxes I recieved they are all listed as part# 163 even though they are different. I am guessing the arm is what is #163. I guess I will find.out which goes where (Identically) when I get the old ones arms off.
does anyone have another place to order bushings for a custom link project?...
just want to see if anyone has any other options..
usedautopartspro
