I will upload photos and couple videos once I’m home. In the mean time I’ll try to explain it in words.
Over the weekend both rear wheel bearings were replaced. All the parts were OEM from camelback Toyota. The concern that I have is this. The wheel bearing had do resistance when pressing into the bearing housing. It even had tendency to fall out once flipped upside down to press the axle in along with the color. Is that normal?
Also, once everything was pressed in. As in the abs ring with the retainer flipped. The wheel bearing had a tendency to walk out of the bearing housing. But everything was pressed in and I fallowed Tim video step by step.
Also the OEM bearing had play side to side. And this is brand new bearing.
Once everything was completed and bolted to the housing. I noticed if you hit the tire. You can hear something rattling inside the drum. The wheel it self was tightened by lug nuts. It actually has some small side to side play.
Could this be that the bearing retainer that is pressed into the back plate is messed up? Although I don’t know why it would be messed up?!? And causing the bearing to have play inside the cup? Or the backing plate moving around the bearing cup it self? Like I said. I’ll upload a couple videos soon. But this is really bothering me. Because everything is oem. The driver side backing plate got replaced by a oem. Minus the wheel bearing retainer cup.
Or could it be that the first retainer needs to be pressed in more? The one that sits next to the bearing.? Although I was able to put the snap ring on. As in the outer rib was pressed below where the snap ring goes. Does it need to pressed in more ?
