Rear window dash switch
jreask
Member
Does anyone know if the rear window switch on the dash is backlit ? I have a 2001 4Runner SR5. I don't know if the center of the switch is supposed to light up or not. Also, does anyone know if this year Runner has a light above the ashtray?
Joe
I have searched and searched and could not find how to remove this switch. Anyone ?
If you just want to replace the bulb then you have to remove the center radio bezel and unplug everything from it (I can elaborate on that if needed). The entire top 'bar' with the switches and buttons can be unclipped from the bezel if needed. It clips in at the middle and at both ends. I would advise against the LED bulbs in general though and especially in this case.
Thanks, so it has one of those bulbs with the plastic base that screw into it, like the rear of the instrument cluster? I replaced those bulbs with no problems. I think they were 24's? Maybe 74's? Can't remember.
Do you know what number bulb this switch takes?
TIA
Joe
