Rear Window not Working??
I just had this issue and it was the most interesting fix. If I pull up too hard on the driver window switch, it won't retracted all the way down, it get's almost back to the middle position and sticks, only when I pull up on it a little too hard. This caused all my rear windows to stop working. I just barely touch the driver switch and it clicks back into it's center detent and all the windows work again!
super old bump.. However..
when i press the down rear window button on the remote.. it beeps and then only cracks open..
when i use the switch inside it works up and down...
Am I doing it wrong?
any ideas....
Hi, did you ever get to the bottom of this? I have the same thing - cab switch works fine but if I try and open from the rear door switch it opens a crack and then stops. At the same time the rear window de-mister and rear window wiper also don't work until I re-close the window (from inside the cab). Have tried the usual suspects for re-setting...
AndiGarage
