Rear window roll up sensor?
mytyeerinpie
Is there a sensor that allows the rear tailgate window to roll up? My switch could be bad I guess but I rolled ot down to take my top off then when I put the top back on the durned thing won't go back up...
did you put all the bolts in because the driver side one nearest the roll bar actives a switch to send power to the window so it wont go up if the tops down
Third bolt from the back on the drivers side is a safety interlock, supposed to allow window function only if there's a bolt in that hole. It malfunctions. Pull the panel and bypass it.
Ok third bolt from the back drivers side, ok I'll put that one it hopefully it fixes the issue. And no I didn't put all the bolts back in I figured that 8 out of the 16 would hold it on just fine, that thing is heavy enough not to fly off while I am driving.
when i first took my top off i did the same thing and sat trouble shooting for 2 hours before i grab the manual and looked
Rialm
