Rear window switch light?
Hey guys. Im not sure if the rear window switch lights up or not?
Is there a bulb back there?
Have you tried turning it on and off? Haha
But what do you see whats wrong with it? Just not on or no bulb? Id take apart the housing to see real quick.
HA.. IT works fine.. It just does not light up like the ECT button next to it.. I cant remember if it even lights up or not.. No big deal.. but if its just a simple bulb ill replace it.. Dont want to be caught in the dark and cant find the rear window button.. :p
Well It looks like it does light up..
http://cartists.com/custom_led.php
I took mine apart on my '98 and yes, it has a bulb. Here is a picture of the rear window switch components.
BackWindowSwitch.jpg~original
I made a thread with some info for almost all bulbs when I switched out the bulbs on my '98. Check it out:
1998 4runner Gauge Back Lighting - YotaTech Forums
I ordered a couple of bulbs to have on hand and change out the one in my switch too. Didn't help. I haven't had the time to take the switch out and troubleshoot the issue. Probably has something to do with those thin light wires not touching their contacts correctly.
Is there a bulb for all the window switches? I recently purchased a 97 and the drivers window switch is the only one that is lit up. Thanks in advance?
I've only ever seen the driver's driver window switch light up, just the one switch out of all 7 side window switches inside the truck.
AndiGarage
